Hey all, have a Strong Spa , about 5 years old now , that is acting up ..........
Haven't used it in a about a week and went to open and check up on the water chems (salt tub running a Saltron Mini ) , and noticed the tub was off and the main breaker was popped and the tub was down to 76 . Reset the breaker and everything started up just fine , heater light came on so good to go , right ? Opened the tub this morning and it was only up to 82 , but otherwise working fine , and the heater light still on .
Pulled the front panel to check it out . Its a Balboa VS Spa Pack (501z M7) , so I figured the heater must have gone bad (still may have), checked voltage at the heater ......nothing . Checked incoming voltage , fine at 240v. Then I noticed the control board was burned up at the heater feed lugs. Checked for voltage on the board heater lugs , nothing. I checked the two little spades that protrude from the heater lugs on the board (looks like they are slightly before the lugs) , and had 240v at the spades, but not at the lugs .
Thinking possibly the heater went bad (maybe due to the salt water) and burned up the board a bit before tripping the breaker .
At this point , I am thinking of just replacing the whole Spa Pack . I can prob just replace the board , but the heater is also probably toast as well . The smarter money is to just replace the whole spa pack that includes everything basically , instead of doing a board replacement PLUS the heater , correct ?
What do you guys think ? I will include some pictures .........doubtful the board is repairable .
