I'm trying to help a friend locate a leak in his pool but we are really struggling to find it and wanted to see if anyone can assist remotely.
A few things to note that are causing concern.
Troubleshooting / observations.
With all of this being said I suspect that the leak is in the pipe from the discharge of the pump to the pool. But we are struggling to pinpoint the location of the leak. Any suggestions are welcome!
Pool equipment setup and layout.
Pump inlet pipes; return from pool / skimmer (I'm not sure which is which) and then return from spa.
Return / supply to pool; Popups, waterfall, main jet / side wall and then spa.
Popup cleaner container. Check valve - not sure what this check valve is for. I was thinking that this is for the pool overflow but we cannot locate the overflow port in the pool. So not sure what this check valve is for. Another possibility is that it could be a check valve going to the popup cleaners but I am just guessing at this point.
Not sure what the vertical tee is for.
Another tee.
There is also this pipe U in the ground by the equipment pad. While the pump is running, I do not feel any water flow through this pipe. I have no idea what this is for!
- The pool looses about 4" worth of water a week. Not sure how many gallons that is, but I suspect it is really high.
- Every time the pump starts, there is a significant amount of air that is pushed out of the pipes and into the pool.
- There is no air in the pump basket strainer. So I do not think that there is an issue in the pipe(s) from the pool to the pump.
- We tried to isolate the 4 pump discharge legs and ran into a couple of problems.
- The manual values did not close all the way and did not want to force them and break them.
- Each leg that was partially isolated resulted in air coming out of the other pipes in the pool.
- The ground was dug up as much as possible (for today) in an attempt to get to the first fitting. No visible leaks.
Another tee.
