I finally switched to SWG so I am donating my chlorine tablets to a friend. I currently have the chlorine tabs individually wrapped in their original buckets in a plastic deck box. I want to take the chlorine out, and store bottles of muriatic acid in the box instead. Knowing the two should never mix, what is the safest way to make the switch? I am paranoid about any leftover chlorine fumes after removing the chlorine from the box.
Am I being too paranoid and should I just make the switch? Should I hose out the box? Leave it open and wait a certain amount of time before placing the muriatic acid bottles in it?
To be clear they will never both be in the box. Just want to confirm if I should do anything after taking the chlorine tablet buckets out and before putting the muriatic acid bottles in. The acid is champion acidblue which is meant to be low fumes but obviously not NO fumes.
Thanks!
Thanks!
