I'm a new pool owner, inheriting an in-ground pool from a previous owner. I had some initial suction issues when I opened the pool but after changing O-ring, I started getting full force again. Then yesterday, it started drawing at what seems to be about half power. It's definitely not enough suction to get a quality suction at the skimmer. Since I've already changed O-rings, I'm not sure where else to go. This morning I wrapped thread tape on the PVC connectors but that didn't help things either.
I have had to restart the pump, clean the filters, etc. several times a day due to how filthy to the pool was. Yesterday, the filter was running great and had churned through an algaecide treatment the night before. The cartridge filter was completely covered after doing that. My concern here is if the pump's internals might be clogged up with algae as well. I did shock the pool last night, so if that were the case, I think it would help that out. I essentially started losing pressure sometime after I shocked it.
This is my pump:
Does anyone have any ideas on what might be happening here? There are certainly things I could do (new pump lid, redo all the PVC, etc.) but that seems like a fishing expedition! Would prefer a more focused approach to solving this.
This is my pump:
Harris H1572748 ProForce Inground Pool Pump, 115/230V, 1.5 HP
SAVES YOU $150 OVER HAYWARD!Carborundum & graphite mechanical seals for longer life and quiet operationLarge capacity extra leaf holding basket while allowing for free flowing operationSee-through strainer cover lets you see when the basket needs to be cleanedSelf-priming (suction lift up to 8'...
www.poolsuppliessuperstore.com
