Would this one suffice? AmazonOK, maybe get the oscilloscope to see what the voltage waveform looks like.
Worth a try for the price.Would this one suffice? Amazon
The new multi meter I just got was reporting 60Hz. I didn’t recognize the significance at the time. Perhaps that tells the story of origin?The mains power comes in a clean 60 hz sine wave.
So, if we see that, or something else, it can help point us in the right direction.
I’m not sure what NEV is but we do live in a semi rural area. 5 miles from town with about 60 houses in the neighborhood.NEV is always a possibility. Do you live in a light suburban or semi-rural area?
It helps narrow down the possibilities.The new multi meter I just got was reporting 60Hz. I didn’t recognize the significance at the time. Perhaps that tells the story of origin?
I'd say it's because of the puddle you inadvertently made on the deck. When you come back later dry, and/or with shoes on, you lose some of the conductivity.The stinging feeling is only repeatable usually after swimming for some time with one foot in the water and one on the pool deck. Perhaps due to lowered resistance on our skin?
I have not yet tried to flip the main on the house to see if the voltage goes away. Maybe a next step?It helps narrow down the possibilities.
There is still a lot to do to try to figure out the exact cause.
Every data point helps.
Neutral to earth voltage. A common problem in rural areas where the power transmission lines can become imbalanced due to non-uniformn phase loads causing a voltage drop along the neutral line. The problem is that most power cos will not do anything about it until it gets much higher than what you are measuring.I’m not sure what NEV is but we do live in a semi rural area. 5 miles from town with about 60 houses in the neighborhood.
I have many neighbors with pools that I would think should run into NEV if I did.Neutral to earth voltage. A common problem in rural areas where the power transmission lines can become imbalanced due to non-uniformn phase loads causing a voltage drop along the neutral line. The problem is that most power cos will not do anything about it until it gets much higher than what you are measuring.
What is the voltage reading at the same spot?static sound on bolts installed after concrete pour?
Thanks @JamesW - the voltage readings on the slide bolts are anywhere from 1.37-1.6. When I tested the continuity previously, it didn't display an ohms reading just the static sound.Everything that is bonded should read at low ohms.
If the meter reads "O.L" (Open Line), then there is no continuity.
If you get a different erratic reading, it might be due to voltage.
Note that voltage readings are always voltage differences.
So, if you measure 1 volt somewhere, it does not mean that there is only 1 volt.
One spot might be at 120 volts and the other spot might be at 121 volts and you will only measure 1 volt.
It is difficult to get a true zero reference to see what the voltage really is.
Probably due to the voltage.Thanks @JamesW - the voltage readings on the slide bolts are anywhere from 1.37-1.6. When I tested the continuity previously, it didn't display an ohms reading just the static sound.
Not always. If a pool is bonded properly so that both the water and the decking are at the same potential, then you will not experience any shocks between the water and the deck even though NEV might exists. The issues come from improper bonding so it can be localized to only your pool.I have many neighbors with pools that I would think should run into NEV if I did.
Any thoughts on the continuity test and static sound on bolts installed after concrete pour?
The inspector has stated he won’t approve the final inspection until a third party comes in to evaluate and ensure there is no voltage differential present. That is planned for next week.Probably due to the voltage.
Do you have anyone scheduled to come out and check anything?
Maybe the Oscilloscope will give us some useful information.
Probably insufficient bonding and a stray current from somewhere.Sounds like you guys suspect the root cause is still likely a bonding issue?
