- Aug 5, 2015
- 122
- Plaster
- Pentair Intellichlor IC-60
WE converted to salt about a month ago and are still having trouble balancing our water. Our salt output had been 3200 then 2850 now 2600. Is that normal to drop that much in a month? We haven't added any additional salt yet, and while the pump runs everyday, we haven't used anything but the hot tub a handful of times. Is adding salt a weekly thing?
We're also having trouble keeping the chlorine up. The pool guys left us at a salt level of 3200, 80% output and FC of 5. Two days later the chlorine was at 12, so we turned it down over the next few days. Seemed to hold at FC of 4 when the output was 30%. Then the salt level continued to drop and the FC went down to 1.5 over about 3-4 days. CYA is at 40, so is that the only culprit? OUr pump is running on high for 6 hrs and low for 5. Should I be adjusting either of those also? Pool temp is still in the upper 60s which I've heard ca affect salt readings?
Lastly, am I doing damage with an output level that low for a few days?
FC: 2
CC: .5
pH: 7.6
TA: 80
CH: 400
CYA: 40
FC: 2
CC: .5
pH: 7.6
TA: 80
CH: 400
CYA: 40
