To calculate total dynamic head you need to know equivalent feet of pipe and the flow rate. It takes some explaining. If you want to figure this out you should start with the Hydraulics 101 post by mas985.
The Mermaid Queen said:Pretty nice design... I would probably soften up that pointy place, as it kind of looks like cleavage!![]()
I like the tile on/below the spillway! I might try to make the color of the spillway a little less bright... to blend more with the retaining wall material.
For the first try, very good overall!!![]()
SeanB said:The Mermaid Queen said:Pretty nice design... I would probably soften up that pointy place, as it kind of looks like cleavage!![]()
:lol: That's exactly what I was thinking. I doubt it would look like that to people once completed but as a sketch it sure does. Like TMQ suggested, I would soften that angle, and maybe even make it a couple of smaller curves to give it more of a free form look.
The Mermaid Queen said:IKWYM about kidney shaped pools... I like a 'sort of' kidney shape, but different, like what you did.
The tile looks nice... much more blue than in the sketch, and the stacked stone has some gray-ish pieces that blend well with the blue! (heck, I sorta even like the purple!! but who can trust the judgment of a goofy mermaid??) On the sketch, on my computer, the tile was GREEN and the stacked stone was a reddish pinkish brown.
I love the multi-levels you will have when complete!
Vegasmom said:I think it looks beautiful so far. I like your idea of using the colored tile on the spa, but if I may offer another angle...I'm not a professional but you may want to consider using the tile on the whole face of the spa rather than segmenting it to just under the spillway. If you are looking to just accentuate the spillway it will look very nice, but to highlight the design of the curved spa, it may look better overall to have it be one surface material.
Definately agree on a grout color that will blend in. If you haven't already planned this for your stacked stone, applying a sealer will make any deposits that accumulate much easier to clean.
Vegasmom said:you may want to consider using the tile on the whole face of the spa rather than segmenting it to just under the spillway. If you are looking to just accentuate the spillway it will look very nice, but to highlight the design of the curved spa, it may look better overall to have it be one surface material.
Vegasmom said:As for sealing the tile under the spillway, it's probably a ceramic or porcelain and won't accept a sealer. The grout will, though and you'll definately want a few coats on there. The stacked stone above the waterline should have minimal buildup because it's not directly exposed other than splash-out. Sealing it will give some protection from that and also make it easier to clean/hose off. I am using a stacked sandstone above my waterline and all of it has been sealed. We don't have any water in ours yet so I can't tell you much more.
As far as how often it needs to be sealed depends on a number of factors. There are inexpensive sealers on the shelves that IMO aren't worth the material they are packaged in. You'll just waste your time and money. Buy a better quality sealer and you'll get a better result. Anything above the waterline that needs resealing I imagine could be done while floating on a raft. 8) Just don't tip over and dump the sealer in the water! No cocktails before you attempt this, LOL....
