There's a statement from one of our members that I find very useful (Catanzaro).
As you can see from the image attached, this is my pool equipment set up.
I will be closing my pool for the first time this year. I have to. No choice. Here are the steps I've created to close my pool. I know...I know... it's a lot to read, but I'm just trying to make sure I hit all the spots here. My pool equipment is very unique and I can't seem to find anyone else that has similar set ups. Questions I have are in bold letters. Please help me.
Steps to Closing Pool:
- Pool should be below 60 degrees.
- SLAM pool 4 days before closing and do an overnight test. Link here:
- Perform the Overnight FC Loss Test (OCLT)
- If OCLT passes, then let FC drift half way down normal range depending on your CYA. For instance, if your CYA is 30 (4-6 normal target), then let your FC drift down to 8. Again, you SLAM your pool at 12. Normal is 4. What is halfway between 12 and 4? Ans = 8.
- Once OCLT passes, skim, brush, vacuum and clean filter.
- Let pool mix for 30min after cleaning it.
- Test Pool (FC, CC, CYA, TA, CH, pH). Note: pH should between 7.4-7.6 before closing and other testings should be within range (make sure your FC has drifted down half way your normal level (additional FC and pH testing may be necessary).
- Once everything is clean and pool chemicals are within range, add Polyquat to the pool water and let your pool mix for 2 hours. You’ll only be adding this one time before closing. The amount you add is dependent on your pool. For instance, add 1 quart (32oz) to a 20,000 gallon pool, and so forth. Note: you want to add PQ no later than 5pm (I would start earlier if you can).
- In the mean time, lay out backwash hose. After 2 hours of mixing, it is time to drain your pool.
- IT’S TIME TO DRAIN YOUR POOL
- After 2 hours of adding PQ, turn off pump and set the multivalve to “backwash”
- Remember to set valve to “main drain”.
- Turn on pump and watch site glass until it’s clear (approx. 2min or until clear).
- Turn off pump and set multivalve to rinse (approx. 2min or until water at end of hose is clear)
- Turn off pump and set multivalve to waste to drain the pool.
- Turn on pump and drain the pool right below the return jets (4”). Again, make sure lever for skimmer/drain is set on main drain only. That way the water is drained from the main drain and not the skimmer.
- After draining below return jets, turn off pump and place multivalve on recirculate (this will bypass the sand filter while blowing out your pipelines.
- Take plugs out from the sand filter, pump filter, heater, chlorinator and also remove site glass, pressure gauge and hose fittings from the multivalve section.
- Plug air compressor to the pressure gauge site. Note: there is a 1/4 pressure gauge opening.
- Verify that your lever is set on main drain
- Turn on air compressor. This will blow air into the main drain pipeline until the water bubbles are at the surface of the pool. Blow air (using an air compressor) for at least 1 minute (depending on how powerful the blower is) and the quickly close the main drain valve. You might hear the "air lock" when you do this. Q. when I close the main drain, should I leave the air compressor on while I close the main drain? That way, water does not go into the pipeline of the main drain?
- While the air compressor is still on, set lever to skimmer and blow out pipelines for the skimmer (again, you’ll see a mist of water to indicate that you’ve blown out the skimmer pipelines). Remove excess water from the skimmer with cup if neccessary. Note: as the compressor is blowing all the water out of the skimmer, it should also be blowing air into the return jet pipe lines as well? [not sure, but I think so 'cause that's how the pool store has been doing it for 4 years]
- Once water is out of skimmer and return jet (misty or air coming out of both), start plugging the return jets (all three of them).
- Turn off air compressor.
- Install Gizmo in the skimmer.
- Move multivalve to “winter”
- Remove stoppers from timer
- Turn off pool breaker
