step marker tiles required?
native sun
9
Lutz, FL
I was contemplating adding some tiles on bench and/or steps, mostly for aesthetics. Was discussing with a couple of pool owner friends, and at least one of them thought it might be Code-required. Anyone know if there is any requirement on this? (self-build so no pool builder to advise).
Thanks
YippeeSkippy
14,960
Evans, Georgia
Absolutely you want them. Safety first!!
I'm sure they are code in many places, but you'd have to check your own local codes. I don't believe owner built pools are exempt from safety codes.
Maddie :flower:
DB-Cooper
353
Austin, TX
It wasn’t a requirement here in code heavy Austin. In fact we hadn’t planned on them, but after seeing a friend’s pool, we added them to our design. I’m so thankful we did. Swimming and stepping is so much easier with them. It’s not expensive/not a lot of tile.
Haymarket
21
Northern Virginia
I haven't heard of a code requiring them...but maybe somewhere? We went back and forth on them and decided to go without on our current build. I just think it looks a little more modern and clean without. In looking at the pool building shows these days....they don't seem to be used at all. I can't really see them making much difference either as far as safety after using pools with and without, so we are leaving them out.
beez74
60
Phoenix AZ
there is no code requiring them they are just kind of a must have so you can see the steps plus an easy sale at the pool companies....the other route i've seen is getting the entire step a different color that the rest of the pool
DB-Cooper
353
Austin, TX
I decided to leave them out.
Do you still have time to change your mind. Just yesterday I was commenting to my wife (while in the pool), "Man, if we didn't call the audible to add these, I'd probably hate myself every time I'm in this pool." It is REALLY hard to see steps without them, you have to be like absolutely paying attention to know where to put your feet.
However, depending on your pool, it may be less of an issue than mine. I have deeper steps, that aren't consistent all the way across. The first step from the tanning ledge isn't a major issue as light refraction is pretty evident in that first 1 foot of drop, but the 3rd and 4th step are extremely hard to make up, especially when the water is churning from activity. As stated, in my case, I have steps that don't go all the way across and have frequent traffic going to/from the swim up bar on those steps. So your mileage may vary.
Werdnaycart
64
Lutz, Florida
Hello! We're in Lutz also! Just building our pool now and also decided to leave the markers out. We found out they're only required by code for commercial pools for our area. Welcome!
