goodyFH
Active member
Apr 6, 2021
30
Auburn, KY
Hello folks, first i want to thank everyone for their help so far. I was nervous buying a house with a pool but with yalls help its clear and awesome!
However, now that i have the maintenance figured out, i want to use as much technology available to make my life easier, adding liquid chlorine everyday isnt bad but sometimes i run late getting home or just cant for some reason.
I've got my pump and light connected with this plug:
it works awesome, i can set schedules and manually turn each plug on/off with my phone from anywhere due to wifi connectivity.
What i would like to do would be add a chlorine pump at the return and add it to the 3rd plug and set a schedule to auto add chlorine each day.
Im looking at the Econ FX with the 15gall gray tank, with 12000 gallon pool i figure i can buy a months worth (7-8 gallons of 10%) add it to tank and be good for the month testing weekly when i do all my other tests. I can put it under my deck to keep it mostly out of sun but will eventually build a wood box to encase it with possibly a fan blowing thru
any problems yall see? any advice is welcome. thanks!
I personally Love my Stenner.
I buy 55G at a time of 12.5% (once per year) from a chemical supply store, and have my tank buried to protect it from the sun/heat of Alabama.
Your idea is completely do-able, and will work well.
i saw your setup and really like it, it helped me decide that i wanted to go the pump route. i really cant see burying a barrel where mine goes but maybe eventually cuz i purchase a year would be super sweet! thanks!
Reactions: RonsPlc
