Cliff,
I must've read that wrong, I stand corrected!
No worries. I wanted to be 100% sure I was correct, so I did a little "independent" testing of my own just now, for curiosity sake.
Here is what I did and what I found out.
1. Killed the two breakers (pump/system), at the panel.
2. Unplugged the IC-60 cell cannon plug from the bottom of the ipH controller.
3. Energized the breakers and initiated a macro that energizes the Filter Pump relay and delivers power to the ipH controller.
4. The ipH controller came alive and immediately began it's 60 minute countdown (I was surprised to even see that).
5. At the completion of the 60 minute countdown timer, the ipH controller status screen then read:
Checking Cell.
6. After about 3 or 4 seconds, the display read:
Cell Not Ready or Off. (btw, this is the same message I get when the pool water temp is too low for the IC-60 to operate. In the winter when I want to dose from the ipH, I have to go into a manual dose mode on the controller and dose that way. It's essentially an "override" function.
7. Then it immediately went back into a new 60 minute countdown mode.
So, it's confirmed for sure.
The ipH will NOT operate in "Auto" mode without an operating IntelliChlor. It apparently looks for some sort of packet or signal, probably from the IntelliChlor Controller Circuit Board. I assume this because others have reported that the ipH listens on the bus but does not send out any packets.
I'm convinced you can never have too much raspberry pi!
I can tell...lol...
The 4's are pretty susceptible to heat issues but for the most part, they'll just throttle. A pi 3B or Pi 0 would most likely run ok even in those hot AZ summers I miss so much. I tried running the code from the Intellicenter firmware on my pi and it worked, they're the same CPU, so whatever you have for cooling in your Intellicenter (aircooled I'm guessing) would probably be the same in a pi.
Great info... Cliff, thanks! That was sort of was my assumptions as well. I can keep the 4B right here on the desk (sort of a master pi, if you will) and if I end up wanting/needing a pi at the panel, I'll get a pi that doesn't generate so much heat (slave pi).
As always, I appreciate all of the insight and advice. When all of this "add-on" automation gets ironed out etc., I'm going to enjoy those "cookies"...
(And Barry White and Marvin Gaye too!)
Thanks again and stay safe....
r..
