That's the way i read it and did it. There are indents in the head you pop out or drill out. Then if the tube breaks the juice will flow back to the supply tank.
No images but once you get your pump it will be in the instructions. Pump should be mounted with the head facing down and a return line is fitted into a hole you drill in the head. A great idea i say.
Pump has a CR 1220 3V lithium battery to keep time. Needs to be changed annually.Question for EconT users: does the built in timer keep the time when the power is off?? Is there a batter backup? Some of us have the outlet wired off the pump timer so that the Stenner outlet is only hot when the pump is on.
Regnar,Looks like I will let you all know how well their customer support is. The Day button on the control pad is either bad or not installed. I cannot feel a click and nothing is happening while pressed.
In manual mode the pump works great. I don't feel it's terribly loud or annoying. Should be barely noticeable from 10 feet away.
If your wonder what's inside or how to change the battery here is a photo. Also a photo of the plugs warning label. Have to figure out what kind of plug they want to have this in for outdoors.![]()
Yes the motor is probably offset too much.I think you could but the power wire would be coming out of the top of the pump and the motor may come in contact with the PCB.
There is no access panel per se. In order to get to the battery you have to open up the main housing. It’s held by 2 screws.Question for anyone that has mounted their Stenner Econ T's into a Bud Industries NEMA box like those pictured above: where is the access panel for the little backup battery that the Econ T uses? Is it serviceable if the pump is mounted as seen in the photo immediately above?
I think the tube that needs to be replaced is on all of them. Being variable speed or fixed doesn’t change that.There have been a couple of other postings about this pump in just the last couple of weeks. I don't know if this line is new, but when I researched I didn't see a lot about them. May likely be the perfect pump since it has a timer already built in. I had an easy way to handle the timer and I'd read several threads that the variable speed pumps needed maintenance every year or two at the tune of $40 to $50 to replace a part that wears in the variable speed pumps. I don't know if this is true in the Economy series.
