- Oct 25, 2015
- 5,845
- Plaster
- CircuPool RJ-60 Plus
Marty's probably helped more through the exchange process than anybody on here. You're in great hands with him.
Thank you, draining water off is scary, I want to push it as far as I can, but not too far. I think I can safely drain to just below the light. That's what I am hoping.Great job on checking the CYA again... I know all this is a pain, but you are going to be an expert on managing your pool!
It was that kind of light, I pulled off the 1 screw and it had YEARRRRRRSSSS worth of gunk and algae behind it.Can you take a picture of the light? If it's the kind held on with one screw, you can remove that screw and the whole light can come out. It's also somewhere that needs to be checked for algae and cleaned out (the light niche).
Yeah, I scrubbed all the gunk out from behind the light.Wow you drained a lot. I would start filling it immediately. If you have another hose I would also keep the sides of the pool wet. You dont want that plaster to dry out.
I think you mentioned that you open up the light and scrubbed behind, but if you did not do that, now is a really good time. Also get the remaining water up to SLAM level while filling.
Did a quick test while its filling:That's great with your drain. You have more nerve that I would have but looks like it worked out for you. You should have your CYA in great shape when you fill. Please post a set of test results when you fill and we'll go from there. What's the FC level now? Based on your previous results you'll probably still need to SLAM. But looking at your water clarity it should be short.
You continue to make huge progress. Congrats!
Chris
Add it now, while its filling? Without the pump running, its not high enough to turn it on yet.I'd add .5 gal bleach now and each day to keep algae from growing until you're ready to SLAM. It's hot and sunny here now. Perfect for algae.
Chris
You'll want to do it again during the SLAM to ensure any algae back there is dead dead dead.Yeah, I scrubbed all the gunk out from behind the light.
