- Oct 25, 2015
- 5,845
- Plaster
- CircuPool RJ-60 Plus
What should I buy at the store to get the pH up that is cheaper than the pool store. The bottle that I have from the pool store is only about 1lb left, according to PoolMath I am going to need 5x that.
There are actually several inexpensive ways to do this. I would use whichever is best price and available easily. It's rare that we need to raise pH, I have only used soda ash once. Please see the excerpt below from Pool School. If you go with Super Washing Soda Detergent Booster be sure to read carefully the underlined paragraph. All of the products listed below are better cost than pH up at the store.
Chris
Raising pH
PH can be raised in three ways: borax, soda ash, and aeration. Borax is usually the best choice. Borax raises the PH and also raises the TA level just a little. If your TA level is low soda ash will raise both the PH and TA levels. If your TA level is high, aeration is best as it will not raise the TA level at all. However, aeration is rather slow compared to the other two.
Borax is available as 20 Mule Team® Borax Natural Laundry Booster. It is sold in the laundry detergent section of most larger grocery stores and some big box stores. Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
Soda ash is available as ARM & HAMMER® Super Washing Soda Detergent Booster. Do not confuse this with ARM & HAMMER® laundry detergent! It is sold in the laundry detergent section of most larger grocery stores and some big box stores. It is also sold by pool stores under various names, including PH Increaser, PH Up, Balance Pak 200, etc. Soda ash is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
Aeration can be provided by a SWG, spa jets, waterfall, fountain, return pointed up so it breaks the surface, air compressor, kids splashing, rain, etc. It can take some time for aeration to raise the PH. The higher your TA level, the faster aeration will work.
