- Jun 1, 2018
- 14,259
- Vinyl
- Hayward Aqua Rite (T-15)
Your cell produces .98 #/day
Put that in the settings of poolmath.
Then you can add your swcg settings just as you would a chemical instead of making a note. Select swg from the sanitizer list.
It will show the addition as ppm fc.
You can also tinker with effects of adding to help determine the appropriate run time & % needed to meet your current daily fc demand.
The swcg should turn off if the pump stops & the flow switch is operating correctly. But!
It should also be wired in such a way that it cannot operate if the pump is off not solely relying upon the flow switch as they can & do go bad.
Post pics of your setup to confirm it’s wired properly.
