We are starting the process of looking to have a new IG pool installed. The pool will be primarily used by my wife and me and occasionally our 2 grandkids ages 5 and 10. We are in central California so warm summers. The dimensions that will fit in our rectangle-shaped backyard will be about 14’x36’. Depth 3.5’ to 6’. It will be straight on the far side with a few curves on the side closest to the back of the house. Curves on the shallow end as well. We plan having a waterfall on the deep end. No spa. No Baja shelf. Considering a wider first step on the entry side for sitting. Bench on the deep end. The shape will be similar to the pool in the picture without the l-shape and we will have a waterfall where the grotto is.
Before we meet with a few PB’s any thoughts on the above as well as some of the items we are considering below would be appreciated.
As for exact equipment I’ll post models once I start greeting estimates but generally considering the following:
Decking will be salt finished cement
Considering similar coping as that in the picture
Wetedge signature in Laguna blue
Plumbed for solar no heater
Waterline tile TBD
Thinking of SWG
Automation
Would like Pentair equipment
At least one LED pool light
We have existing outlet for robot
Light at equipment pad
Overflow port
VS pump but will I need a separate pump for waterfall?
Jandy valves?
Leaning towards cartridge filter
At least one vacuum port but should it be pressure side?
Will have to see what designer comes up with for number of skimmers and returns but if possible what would be appropriate?
Am I missing anything?
Thanks in advance
Waterline tile TBD
Thinking of SWG
Automation
Overflow port
Jandy valves?
Thanks in advance
