Hi, I just finished a successful slam - and passed the three parameters test (clear, no CC, overnight hold). I am somewhat high on TA and working to lower by lowing PH and aerating. It is gradually coming down. Now I need to get to work on my step stains. Vitamin C does clear it. I had this trouble last year, used citric acid and poly-fil in basket. Ended the season with bright white steps. Also drained water below return for winter. They were yellow/orange when I opened. I had water tested for metals last year several times - and no metal ever showed up. Has anyone had similar experience or have advice on how I can do this the right way. My previous process was lower chlorine, add citric acid, filter out with poly-fil, then bring chlorine back up.
