HELLO EVERYONE!
I HAVE A 5-YEAR-OLD SR333HD STA-RITE MAX-E-THERM HEATER ISSUE THAT RECENTLY DEVELOPED:
WHEN THE FILTER PUMP TURNS ON (VIA TIMER, POWER THEN ALSO GOES TO THE HEATER) THE HEATER BLOWER STARTS TO RUN CONTINUESLY, EVEN WHEN NO HEAT IS CALLED FOR. ITS JUST THE BLOWER RUNNING AND NOTHING IS DISPLAYED ON THE CONTROL PANEL. AND, THE HEATER WILL NOT TURN ON WHEN HEAT IS CALLED FOR.
I BELIEVE THE IGNITION CONTROL MODULE (42001-0052S) IS THE PROBLEM BUT WANTED TO SEE IF ANYONE EXPERIANCED THE SAME ISSUE.
THANK YOU!
JOHN
THANK YOU!
JOHN
