Sta-Rite heater not starting
alan_in_philly
3
Philadelphia, PA
I just opened my pool for the summer and my heater isn't starting up. Hoping someone might be able to point me in the right direction.
Here's what I know:
  • Heater is a STA-RITE Max-E-Therm 333HD
  • Control panel powers up and shows pool water temperature
  • When I press 'Pool On', the 'Service Heater' light comes on immediately
  • Disassembling heater revealed rodent nest - I cleaned out all the debris (the wires don't appear to have been chewed-through)
  • 'AFS' error light shows red on back of control module
  • I do not hear the air blower kicking in when I try to start the heater, but the motor for the air blower did feel warm to touch [Interested to hear how I can test the air blower to see if it has seized - my motor cover doesn't have vent holes so I can't see what it's doing]
  • I removed the igniter, and it seems to be intact (although the gasket had disintegrated) - I am ordering a new one
  • Other parts look intact - no damage to the air orifice or any of the air tubing
  • Flow of water through the heater is good. Backwashed the filter and no luck
At the moment I'm stumped as to what I should replace first. Any ideas?
Alan
Here's what I know:
Alan
Remove the venturi on the other side of the blower away from the motor. You should be able to reach in with a long screwdriver and try to move the fan.
Reactions: alan_in_philly
