Sta-rite DYNA PRO-E pump leaking water.
Hello all,
I notice the skimmer was not strong because alots of insect in the pool. And then i notice the PSI on the pump filter a little higher then usual. I think normally its at 18 psi now at 22 and "max" is 24.
What I did is clean the filter pump. The filter is brand new from like a month. I just clean and evacuate the water out from the filter pump. Then the pool pump I have notice normally its take 2 minutes to fill up. Now way longer and it doesn't "fill up" maybe like 80-90%.I have close the cover and its really tight. I even bought new "ringer".
Here the water is like flat not too much movement.
I even change this part from here ,under the cover.
Thank you for your help all
You need to get the shaft seal replaced before water damages the motor.
I think I have found the problem. Yesterday with the Hayward CX225XREM filter cartridge (1 month) we have put like a spray to clean it.
And then we have let it stay for a couples of minutes and reput back the filter and eveyrthing was working very well.
PSI was at 16 and took less then a minute for the "motor basket" to fill up and no air seen.
Now this morning we clean the polls because it was not working for a couples of days.
Then same issue re-occur, the jet is not strong and I notice the PSI went up back at 18 AND the "motor basket" is fill up to like 80 % more then an hour now.
Did I have to put a "Filter Cleaner" before usage?Because I tested without the filter and it was working like "usual".
Thanks
