I lost one of the two tabs on one of my two Pentair Admiral S-20 skimmers a year ago. Went without a Weir for last year, and tried a Venturi Turbo skimmer basket, w/o Weir. It seems to work ok while the pump runs, but of course, some of the leaves that stay on the surface of the skimmer will flow back into the pool after the pump shuts off.
So, I decided last night to buy this spring-loaded Weir door:
I found it at another web store for about 1/3 the price so I bought two. I measured an old broken Weir Door, and it was 5x8 exactly, so I bought a 5x8 to replace.
I hope this will work well.
Only one of the two tabs on the S-20 Skimmer is busted off...I am not quite sure how to install the new Weir door just yet. Should I install it from inside the pool through the wide opening or kneeling on the deck with the skimmer cover removed. Should I install it inside the existing tab, or outside of the existing tab (poolside)...? It looks like you put it in place and pull the string to let the spring(s) out. How much force doe the springs apply? Is it adjustable after installation? Inquiring minds want to know. Looking for a You Tube install vid.
Generic Weir Door Compatible with Pentair R240008 and Others, 8" - 925 - INYOPools.com
R240008 - WEIR, UNIVERSAL 8IN (R240008)
www.inyopools.com
