How much did you end up draining? Say 75% maybe?? Reason I ask is that’s a LOT of green for a pool that’s had a water exchange.
Based on OPs prior posts it looks like they were able to drain only about 1/3 to 1/2 of the water volume. So lots of baqua left in there I'm guessing!How much did you end up draining? Say 75% maybe?? Reason I ask is that’s a LOT of green for a pool that’s had a water exchange.
If we drain to leave at least 18” to be safe on shallow end of my pool design, this by our calculations will drain around 5760 of 14,200 gallons and if we take it down to 12” on the shallow end of pool would allow to replace about half of the water, around 7K gallons.
Drained down to 14” on shallow end
Not sure but the crazy thing is that I have JUST hit 15 ppm FC and have not had really that much surface scum and Baquagoo. I am cleaning the surface and edges very regular and testing water as much as I can. I have put in 11 gallons of bleach to this point. Will stay with it. The water is looking very clean other than the green (if that makes sense)!Ok. Weird … what does “Test” do??
Better hang on, it may be a bumpy ride! Thanks for the cheersSO in to watch and![]()
You have NO idea about Kim. That cheerleader icon was invented for her. I forget the code but if you type [kim] or whatevs, the pom pom emojii shows up.Better hang on, it may be a bumpy ride! Thanks for the cheers![]()
You’re going to love testing for chlorine. So much easier and MORE ACCURATE than baquacil “guess”-strips. You test your water, know exactly what’s in it, PoolMath tells you exactly what to add and BOOM! you’re done. Pool sparkles and you get to drink a beer and torch some animal meat on an open flamePriceless!
That’s VERY odd yet a very good sign. With that much green showing I would have thought that you’d see a large drop as the chlorine breaks down the Baqua. That said…..it’s great that it’s not all getting broke down.FC still @ 15 with 30 min since last Chl addition! Checking about every 30 min.
No doubt this is your biggest asset here. The more effort you put in, the better it goes regardless of 'how bad' it was to startTesting every 15 min to stay on top of it!!!!!
I agree, persistence and good guidance!No doubt this is your biggest asset here. The more effort you put in, the better it goes regardless of 'how bad' it was to start
