Hi all! New to the site, just discovered it while trying to research an issue I'm having with my pool. New pool owner, our pool was finished about a year ago so i would be extremely grateful for your advice.
A few days ago I noticed this spot on the floor of my pool, so I dove down with goggles on to check it out. It's wasn't something I could brush out so I went to the local Leslie's pool store to see if they had any advice. A lady working thought it might be yellow algae and recommending me putting dry acid in a sock and dropping it on that spot. I was able to do that, however the spot did not go away and something new resulted, a dark trail running from the spot to the drain, from what I'm guessing is how the dry acid traveled to the drain in my pool. Thoughts or advice on how to clear up both?
Thank you in advance!
