Pool builders add that spigot often.. It gives them a place to pressure test the plumbing, when the pool is being built. You can use it to drain excess water, if you wanted..
If you get a lot of leaves in the pool, you can get a "leaf eater" type vacuum, hook a garden hose to that hose bib, turn the pump up high and get great water pressure and not dilute your chemicals with added water from a bib on the house.
