I did not use the main pump. IN,
When you used the main pump to drop the water 18", did you have the Intake valve set all main drain or was it set 50% skimmer and 50% main drain???
It literally worked fine yesterday morning. Then not after I dropped the pool level and refilled.That looks like an impeller issue.
Would that just give up the ghost in one day?Lube the o-ring on the union connected to the pump on the suction side.
No one asked me the psi.That’s exactly what someone with a clogged impeller would say. You never answered James, what’s the psi and does water come out of the air relief? Turn pump off and make sure it stays off and remove basket and check the impeller with some tweezers.
No, I did not. But yaupon leaves are tiny. If they make their way through the skimmer they can easily get through the pump strainer.Did you run this without the pump basket in it? Leaves shouldn't get to the impeller.
