Mike,
I was kidding about just doing one at a time. Notice the littleWhat I meant to say is... based upon the screenshots, it made sense that they worked when turned on one at a time..
Why do you have two "Sam2" lights??? I only see one in the set up..
If this were my pool, I would remove the lights listed in the Special lights window one at a time and see if the spa problem goes away.. I would start with the Sam2 lights..
If nothing else, it might allow us to narrow down what is causing the problem.
Now that I think about it, Sam2 is not an IntelliBrite, it should be Sam... You need to change that...
Thanks Jim, i replied earlier but I don't see it here. I know what you meant in the other post, and i think my lightheartedness didn't come through in my reply. it's all good.
The sam2 lights are Pentair globrites. there re two of them in my baja ledge. the pool light and spa lights are J and J electronics LED's which are intellibrite compatible. should I change those to something else? i changed the sam2 lights to "pool lights" as they are in the pool and not the spa. this had no effect on the original problem.
another issue though is that the pool light and spa light (J and J's) do not sync with the globrites when set on a themed light show. i gave up on that unless anybody has an idea there?
