I believe there is a problem between the spa drain to the pool pump. What are the steps to determine if something is blocking this drain? All the pipes are underground and there doesn't seem to be a check valve on the spa side pipe. Suggestions for next steps of troubleshooting / fixing this? Thanks!!!
Further info on my troubleshooting: new variable speed pump from last year; all pool modes work perfectly; spillover to spa works; the only thing that doesn't work is the spa drain (whether it's in spa mode or spa empty mode). When in one of those spa modes it looks like a very small flow of water and a lot of air in the filter pump.
