Hello,
I want to make sure that the spillover will not dribble down the glass tile waterline or not flow out etc. I was going to use a glass tile on the spillway but the tile guy said that even with a pitch the water would dribble down the glass tile and calcify it. Instead we said that we would use the porcelain coping for the spillover but its bullnose.
1. I have read that we need to notch the bullnose so it spills out.Where is the notch? Do you see it? Is it sharp? The porcelain has been tricky for them to cut and I'm not sure how they will manage the notch without ruining pieces?Is the notch done with the saw? Just scraped with a sharp object?
2. Another option to the bullnose is the manufacturer has a color match mitered L shape now (see photo). However, for it it stand away (2" or more as needed for the spillway) the shape may be an issue here. Would this work?
3. I know the spillway shouldn't be flat. It needs to be pitched. It was prepped flat. How much pitch?
Please share your knowledge and ideas. Thanks!
Thanks
Thanks
