Guys
A client of mine has an outdoor spa and asked me about the proper sanitation of it so I have a couple of questions regarding spa sanitation.
I know that if we use chlorine for spa sanitation we are going to have more amount of disinfection by products due to high bather loads compared to swimming pools.so chlorine alone will not be a good choice
So I am thinking of using an ozone system for sanitation. I think it should be a good option for spa due to its short complete turn over time
but the problem is that it is an outdoor spa so algae is going to be an issue therefore I plan to add liquid chlorine one time throughout the day when the pump is running to stop algae formation.
So my questions are:
1-Is an ozone system alone a good option for spa sanitation?
2-If I am using liquid chlorine to stop algae formation does ozone eliminates DBPs formed after adding chlorine?
3-He is using well water to fill the spa and it is a hard water as I tested.is there a way to reduce the hardness of water before in enters the spa? I am thinking of a water softener
P.s: if there is better way for spa sanitation I'd be grateful if you share it with me
Thanks
Thanks
