My freind built his own spa pool. The system has 6 spa nozzles 4m3 hr supplied by a dedicated 2 hp pump output 28 m3 hr.. the discharge of the pump is 32mm, reducing to 2 x 50mm pipes which supply the pipe loop at top and bottom. The top nozzles on the array , left and right..pump out water full blast, the bottom ones a little less and the middle ones weak. No air is sucked but it sounds like its trying i try to help him and the only thing i could suggest was to install a valve on the lower inlet 50mm line. When we did this and half closed it, the too right nozzle started working for a while and sucked some air ! We tried closing off some nozzles and chocking in the pump but nothing helps. If you blow down the air pipes the bubbles come out two of the nozzles on the right and one on the left, but not all ? I wonder if his pump is undersized or if the nozzle extensions that appear to have been fitted are correct ? Maybe some of nozzles are glued up ?... I was not present at installation so i have no more info. Any ideas what is wrong ?
