Spa stopped heating a couple weeks ago (2005 HotSpring Jetsetter spa - 200 gal) Had the local pool company come look at it. They said heater circuit board was bad ($170) and the actual heater ($370) plus shipping and labor. I'm not sure if the actual heater doesn't heat but there's a definitely a small leak in it. They also said if that doesn't fix it then the main PCB could be causing the problem (350). Also, other parts could break while installing. Also, not sure if this is important but I noticed before calling them that I don't have a pressure switch which they confirmed. Also, the spa cover is bad, it was getting water logged and is 2 pieces (the hinge tore) My fix for this was a 70 dollar spa cover cover (basically a grill cover for spas) it doesn't get water logged and I haven't noticed heat loss or high electic bills (I just make sure to push the 2 pieces together tightly after using).
So my dilemma is - 1. do I want to spend that much money on a 15 year old spa? 2. go without one. 3. get a new one 4. try to find cheaper parts and fix it myself 5. is there some type of external heater that would work? something like this ...or something else I haven't thought of?
Also, I have a Hayward nat. gas heater. It has a spa mode. Anyway to tie it into that? It's a good 70 feet from the spa but I would consider moving the spa close to it, I think the new location would be better than where it is now anyway. How does a spa connected to a heater like this even work? And it apperas maybe this method is for in-ground spas? Based off a little research via google it appears you connect a suction line to existing plumbing where you can turn off/on the pool/spa suction and then do the same thing on the return side...so either the pool is running or the spa is running? We only use the heater in May for the pool but for the spa to remain a constant temp (as it does now or used to) wouldn't you have to run the pump 24/7? Or heat it up prior to using each time? I'm sure I'm missing something as I know everyone here loves their convenience.
What have others done in this situation?
