New'ish build (filled in Dec). Each morning I am losing water from the spa into the pool. The spa loses water up to the jets, but then nothing more. The reason I know it's into the pool is the water rises in the pool without adding more water. Any ideas what would be causing this? Check valve issue? Thanks!
