- Aug 15, 2021
- 30
- Plaster
- Saline Generating Systems Breeze 540
About 3 weeks ago I switched to spa mode for my daughter and some friends. A short time later I noticed that the level in spa had dropped almost 1 foot. I had to keep switching back to pool mode allowing the spa to fill up through the single discharge to spa, then return to spa mode and turn the heater back on. This happened several times throughout the day. Since then, the spa loses level when the pump shuts down. While running in normal pool mode, the pool will flow a little into the spa overflowing back to the pool. After shutting down, the level drops more than a foot. I suspect that my discharge valve is not sealing, allowing the spa to flow back to the pool after shutting down, and allowing it to directly flow to the pool when in spa mode. The level was down to just below the jet on the left. I tried to measure the spa level relative to the pool and it's pretty close. We got some rain a few days ago and the level in both pool and spa are higher now. I suspect the head is equalized across the piping. Thoughts?
Is there anything special about Jandy valves or are the internals essentially the same and I should order the o-rings? Diverter also?
James
James
