Set up: Pools is salt system, 18,000 gallons, DE Filter. Pool heater. Booster Pump for pool cleaner. Poolside elevated Spa drains (overflows) into pool.
A week ago spa water level dropped overnight. Ordered OEM Jandy check valve flapper assy. (I have done this before successfully) Had to wait a few days for OEM part to arrive. When I replaced check valve, the old one still looked to be in good shape and seemed that it should still seal. So after installing the new check valve assy, the next day the Spa water level still dropped.
I am ordering Jandy 4720 never lube diverters and should get these tomorrow.
My questions:
Could the diverter valves be my problem?
Could it have been the diverter valves instead of the check valve causing the problem?
And if I replace them and still have the same problem, what's next?
Thanks
My questions:
Thanks
