I have a pool and spa, where the spa water overflows into the pool when in normal "POOL" mode. When in "SPA" mode, an automated valve closes the pool inlets and leaves only the spa inlet. Normal stuff and all was working fine until recently.
Today I set it to SPA mode and notice in just a few minutes the Spa level went quite low, below the jets. The jets pressure were also lower than normal. When back to POOL mode, jets pressure would go back up to normal pressure and spa would overflow as normal.
I have minimum pool experience but logically I am thinking two hypothesis:
1) Major leak in the SPA inlet pipes, so when automated valve starts sucking via the Spa pipes only, whole system loses water before it reaches the pump and hence why return to SPA is lower pressure and level is dropping.
2) There is another automated valve (Jandy CVA-24) on the return (splits between pool and spa). This valve is currently set at 45 degree between both Spa and Pool, sending water back half/half (I suppose). This valve is not moving when switching from Pool to Spa mode but I dont remember if it ever did move, hence I am not sure. But I wonder if when in SPA mode it should send 100% of water to SPA only and that is why pressure and water in the spa return is low (because part of the Spa water and being sent to pool). Not sure how to move this valve manually to test it.
Any thoughts or other ideas?
Thanks a lot!!
Thanks a lot!!
