spa heat pump automation
r3206
47
dade city fl
Pentair Intellichlor IC-40
new pool owner. I noticed that when I turn on the spa, to spa only mode, that heat pump heater will automatically turn on.. if I have heat setting set where the water needs warmed. (without actually hitting button for heater).
so if I wanted to turn just the spa function on without heater being run, the only thing I can do so the heater don't kick on, is to change heat setting to a lower degree so it doesn't kick on.
is this right? or should I be able to run the spa and turn on heater when I want it to heat, not automatically?
(we have pentair heat pump and pentair equipment )
ajw22
24,588
Northern NJ
Pentair Intellichlor IC-60
What specific Pentair automation do you have?
Please create your signature with details of your pool and equipment.
r3206
47
dade city fl
have the pentair ut 140 heat pump
pentair easy touch
ichlor
intelliflow vsf
ajw22
24,588
Northern NJ
Do you have Screenlogic II?
What device do you use to control your spa?
@Jimrahbe
Jimrahbe
21,145
Bedford, TX
r.
Set your Heat Menu option to "Off"...
That will set up the system so that you have to manually turn the heat on..
r3206
47
dade city fl
i
r.
I do that on my phone and It literally turns itself back on. I watched it after I turned off (by hitting the off button?) turn itself back on. the only way to keep it off when in spa mode is to make temp off pool water low so heater won't come on.
r3206
47
dade city fl
yea mine don't look like that, is that from I phone?
Jimrahbe
21,145
Bedford, TX
r.
On the main panel itself, go into the Settings Menu and find Manual Heat.. Set it to off and see what happens.
r3206
47
dade city fl
r.
ok I will try that thanks
Jimrahbe
21,145
Bedford, TX
No...
Look under "Settings" for Manual Heat on/off..
You have to scroll way down..
r3206
47
dade city fl
No...
ya that was under settings and I didn't see maual setting only settings for heat pump but not manual
Jimrahbe
21,145
Bedford, TX
r.
On my EasyTouch when I go to "Settings" and scroll down, I come to Heat pump, but if I keep scrolling down, through all the remote panels, way down near the bottom of the list is "Manual Heat on/off"
I have no idea why you would not see the same thing. :scratch:
