having trouble keeping spa filled . at first spa would fill to the spillover when in "pool mode" but when pump shut down, in ten minutes level would drop back down to the pool level. we thought it was a faulty check valve in th pool to spa bypass loop - and after that was replaced the spa will remain full if the pool mode is on, or the pump is not running. But if i switch to "spa mode" the water level in the spa will slowly drop , even below the level of the pool - once spa mode is off the water level in spa remains there until pool mode put back on and then it slowly refills. there seems to be a slow loss of water level from the pool - about 2-3 inches a week in southern cal - cant figure out if there is a slow leak somewhere ... though pool person does not think thats excessive water loss.
any thoughts are appreciated.
