- Nov 29, 2015
- 640
- Plaster
- Jandy Aquapure 1400
I'm guessing that one of the valves is not turning all the way, an alignment issue, that's causing this ?
ive attached some images of the plumbing
I'm considering just ordering new valves and actuators. Ive "repaired" one of the limit switches in one of the valves already
One question is do I need to replace the valve housing or can I just buy the guts and the actuator and leave the body of the valve ?
Another is that it looks like a check valve on the return side of the spa ... Is that required? Guessing I should replace the guts of that as well ?
thanks to this site I do all the maintenance myself so I dont mind spending a little cash and replacing tired parts
THanks in advance
THanks in advance
