I’ve been running freeze protect for the last couple of days with spa drain, spa return and cleaner valves open to circulate everything 24/7. We have not subsequently warmed up enough that freeze protect is no longer needed (maybe for a few hours tonight). This is my first time having to do this, so I’m sure what I’m noticing is normal but I can’t fully explain it I need some help.
When freeze protect automatically shut off an hour ago I noticed that my spa started draining into my pool even though the pump was off. The spa main drain valve was manually opened as part of my freeze protection preparation’s so I’m sure water was draining from the and somehow making its way into the pool through the returns. But I’m not sure how or why.
