Hello Members,
So I'm a new pool owner and i have a common problem of the spa draining into the pool. I read all the articles on this forum that i can find and i haven't had any luck. My spa is above ground and while in use or not in use it is draining back into the pool. It drains slowly like 2 inches every 15 minuets. Its an elevated spa and the water is going below the jets but still above the main drain, its basically leveling out with the pool. Today i will be performing a bucket test to see if its a leak but i don't think its leaking because the pool level is rising and falling as the spa fills and drains(i put a piece of tape on the water line to test this). Based on everything i have read on the forums about this problem i have already replaced both Jandy spring valves as well as both the diverts below the two actuators. At this point all its either a leak which i don't thins so or one or both 3 way valves are old and need replacement because its not creating a tite suction with the diverters? i don't know i'm out of ideas. Any help would be greatly appreciated.
Thank you,
Struggling pool guy Jason
Thank you,
