Hi guys,
New pool owner since 2022 and learning to do my own pool maintenance. I’ve had this issue about a year ago where the spa wouldn’t hold water when the pump was off and it would drain down to the pool level. I replaced check valves, and opened up the actuators and checked their locations but it looks like it’s happening again. I have attached a picture of my swimming, pool and my equipment. Yesterday it took less than 20 minutes for my spa to go from full to pool level. Do they make heavier duty Pentair spring loaded check valves? I have the type with eight screws and the spring loaded oval shaped flapper, I would think something that’s bigger. Would cover more surface area and block the spa water from getting to the poolside? In my research, it’s either going to be the check valve, flapper, or those electronic actuators. Any help would be appreciated because it is annoying To have this reoccur.
I’ve definitely learned to run the pump during the daytime to come back chlorine loss and allergies so thank you for that and I’ve rebuilt my Pentair 320 chlorinator and learned that it doesn’t work right if you fill the tabs all the way to the top.… So hoping to learn more. Thank you!
