- Aug 22, 2023
- 155
- Plaster
- Pentair Intellichlor IC-40
I finished 30 day startup on our new pool. Installed all the intellivalves and programmed the set points. When I turned on SPA mode, the intellivalves moved to SPA and booster pump came on also. I tried to change the Intellivalves to off but they are greyed out. I ended up having to delete the booster pump. Is there away to change the valve settings? I also cannot get booster pump to run either. Ideally I would like the SPA button to start the booster pump and create a separate SPA heater circuit to turn valves to SPA mode and start heater when I want heat. As it sits now I click spa, the valves move to spa mode and when I turn heat on heater bypass valve operates properly and heat comes on. Do I need to use one of the AUX circuits to add the Booster pump and call it SPA Jets?
