We are having two issues with our spa blower (Air Supply Silencer 2hp).
Thank you.
- Blower pops off the PVC pipe. It's been in use (installed) for a couple years but now all of a sudden is doing this. What could all of a sudden be the cause? I read that it's ok to secure with a couple screws threw the PVC and check valve but if there is a root cause I would rather resolve vs. securing with screws and having that cause any issues.
- When the blower does stay on it will shut itself off after a few minutes and won't turn back on for 10 or 15 minutes. Could it be overheating? Could there be a blockage in the pipe causing a back flow issue?
Thank you.
