Hello,
An electrician converted my hot tub from 120V to 240V on tuesday, and since then the heat has slow dropped and now sits at 95F - all other functions (jets, lights etc) are working. It's a Dreammaker single 2-speed pump and a Balboa VS3FL4AV (PN 56902) heater pack. The manual I have instructs me to remove the J11-J32 jumper and flip the A10 DIP switch to 'high amp mode' which I did. We started up the spa and heat started to steadily drop (despite being set at 103F).
I did some internet research and found documentation on resetting the persistent memory switch - J43 for my spa. This was not in the documentation I was given. I bridged that (there was a bridge clip on only one pin that I used to bridge the 2 pins), turned on, waited until the display went to 'Pr' (Prime mode) as instructed, turned off the spa, removed the J43 bridge, turned on again, saw the message '12' come through on screen at start-up, set the spa back to 'St' (standard mode) and temperature back to 103, and still the spa hangs on at only 95F (screen shot attached with temp at 97 was yesterday morning). My electrician is coming back to check things on friday, and my dealer has a call into the spa rep whatever timing that will be.
Anyone have any ideas on what I'm missing?
