Something stuck in main drain opening
etbrown4
99
Have a small main drain in a fiberglass pool located in the side wall down 4.5', just above the bottom. For about a month there's been something organic looking stuck there, and it cuts flow in half.
Can't really tell the makeup or design of the screen, but it looks like the openings might be an inch or so, and the drain faceplate diameter is about 3"
Ideas welcome on how to dislodge or clean it.
The grate needs to be replaced.
The grate is broken and dangerous.
The grate needs to be a VGB certified grate for suction and you need at least two grates for a main drain.
I do not see anything stuck.
Where is the stuck item?
Maybe you can use a pump to suck out the item.
Remove the grate and vacuum the line to remove any debris.
Turn off suction to the line until it can be made safe.
It's easy enough to pull from the skimmer only.
So Besides diving, or pool draining, what are the options to clear this drain?
Try a "Drain King" #186 in the suction line from that port. Without a proper VGB-rated cover that is a dangerous port to be un-covered/partially covered and in use. You should use only the skimmer until it can be covered properly.
Reactions: proavia
As mentioned, it's simple enough to operate with skimmer only.
Back to clearing that drain, the drain king 186 seems plausible.
I've seen pool guys winterize drain and return lines using a 1/4" threaded air compressor line into a drain port at the pump. They limit the pressure to 30 psi, let it build up and then push water from those lines.
