- Aug 23, 2017
- 109
- Plaster
- Hayward Aqua Rite (T-15)
So we had our pool installed this past August and I’ve been doing TFP since inception. I test the ph and FC every other day and do a full testing gamut every Friday or Saturday.
So the odd thing is this. I grabbed a quart of pool water to test and started out with the TA test using the TF100 test kit. I add the green drops and the sample stayed bright pink. Odd I think... it usually turns green/blue. I dump it, grab another water sample from the quart of pool water and again... same result.
Now I’m thinking maybe somethings wrong with the chemical drops? So I decide to check the ph really quick using my electronic probe... it reads 3.9! Now I’m wondering what’s going on? I calibrate it monthly so I wonder if maybe it’s just really off? Though it was fine on Wednesday.
So I decide to recalibrate and low and behold it’s spot on for the calibration solution... so what gives? I dump the pool water and go grab another quart of water and everything is fine... So my question is what happened? I mean I haven’t added acid in about 2 days... being new plaster I seem to have to add acid a few times a week to keep it around 7.8. My thoughts are for some reason maybe a bit of acid didn’t mix with the cold pool water? Current temp is 59, but a whole quart? I have a vsp pump, so I run it about 18 hours a day... turn over shouldn’t be an issue.
I’m kind of at a loss of how I got these readings... I’ve tested the pool hundreds of times it seems and nothing every out of the ordinary.... ever. And all other results were fine after the second round of testing with the second sample of pool water, with a CSI of -0.01 at the moment (pool math). Any thoughts from the TFP brain trust? Thanks in advance.
_________________________________________________________
17.7k gal, 98 ft perimeter, IG quartz, 3HP EcoStar VSP, 1.5HP TriStar Dual Speed, 725 sq ft SwimClear Cartridge, Rainbow chlorinator, Paramount clear O3, Pro Logic controller, 500k BTU heater, AquaVac 500, Spillover Spa, 3 sheer waterfalls, 3 bubblers.
