Some time ago I broke the tightening ring on the SWG coupler.
Chuckiechan
622
Roseville, CA
I have heard you can remove the threaded coupler with a heat gun. Has anyone had experience doing this? I'm using a two piece nut and teflon tape that works fairly well, but I would really like to fix it but there is not enough room to cut and replace.
Yes you can use a heat gun but if it's not your first time doing so, I wouldn't try it here.
Yesterday I tried to remove a PVC pipe with a heat gun and really screwed it up. Ended up having to cut and replace.
They make a socket saver you can use to drill it out which has some decent reviews. I'll be trying this next instead of the heat gun method.
How about a bigger wider picture of the area.
