I'm going to replace my hayward 1hp pump with a harris vsp 3hp for the VS benefits and lower electrical bills (hopefully). I'm also installing a circupool rj45+ swcg.
The hayward pump came with the pool and previous owner did not use any unions or threaded fittings, and I had to fix a leak last year and that's when I discovered this no union issue. Also, the hayward pump (and all of the plumbing) is 1 1/2", the new pump it 2". Between the pump inlet and the diverter valve is only a few inches of clearance. I want to cut the fitting off to remove the pump and was hoping there is a PVC fitting/coupler that will fit inside the 1 1/2 pipe to extend it to a 1 1/2"-2" adapter and then a union:
Anyone know if lowes/home depot will have something that will work without me having to replace the diverter valve?
2nd question: will going to from 1 1/2" to the 2" introduce any restriction issues? I'm by no means a plumbing expert.
Last question: Since the new pump and the swcg have electronics, should I build some sort of cover to go over all my equipment or will it be ok in the open as it is now?
