- Oct 25, 2015
- 5,842
- Plaster
- CircuPool RJ-60 Plus
Avi,Hi Chris,
I am all set to start the slam process today. I will run the pump 24/7, and top off to slam levels few times today. However on weekdays, I will be able to do it only twice (before and after work). Will that be an issue?
The usual schedule setup with the pentair easy touch is as follows:
pool - 10 hours
Spillway - 1 hour in the morning, and 20 minutes in the evening
Waterfall - 10 minutes in the morning and 20 minutes in the evening.
My logical thinking with the schedule is, filtered water should run through the spa to keep it in the circulation.
Is this schedule adequate for maintenance, or should it be tweaked?
I thought the info under our username (pool size, surface etc) is the signature, which I did add. I will look through it again to understand what I might be doing incorrect.
Thanks
Avi
Your setup for maintenance looks fine to me. Main thing to do is just make sure the pool is skimmed and clean. Every pool is a little different so there's no fixed amount of time or amount of pool volume. What do you clean the pool with? Suction cleaner, robot, manual scrubbing? For now you'll be in SLAM mode so pump runs 24/7 and you scrub daily. You'll want to circulate through the spa all the time so you kill all the algae.
Sorry for the confusion on the signature, looks like you figured it out. Please post a set of test results to let us know how you're doing. Remember your pH test will not be reliable at slam FC levels so it's good to start low in the pH range.
Chris
