- Aug 20, 2020
- 5,773
- Plaster
- CircuPool RJ-60
I finally got this SWG all up and running. The generator portion seems to be working well, thanks to some of the questions I had answered on this forum.
One problem I do see is that I redid some of my plumbing to install new Jandy valves and I have a small suction side air leak.
My not so genius idea was to find the leak by wiping pipe dope around each joint until the bubbles stopped showing up in the pump lid. The trouble is that I got through all the glue joints and no change and it’s really messy to remove! So now I’m left with the 7 unions as the only possibility left. (Second photo) I was able to carefully crank the union on the pump a bit and lessoned them a bit, but still have some tiny bubbles building up over time.
So a couple questions:
1. The o-ring on the pump fitting is new but very thin. I’m curious if there’s a thicker one available or a different material that seals better?
2. Is there anything I can do to my valve layout to make the seals more reliable? I suspect that one of those unions may not have been lined up perfectly before gluing.
3. Are there any better unions than the standard HD/Lowe’s variety that I used?
